RVCT 4.0 Build 902 patch for Linux - 软件 - 电子威廉希尔官方网站 论坛 - 最好最受欢迎电子论坛!
芒果冰 ( 楼主 ) 2014-10-15 16:25:23  只看该作者 倒序浏览
分享网盘下载地址:http://pan.baidu.com/s/1hq25tEs
RVCT 4.0 Web Patch Build 902 Release NotesDescription
This RealView Compilation Tools (RVCT) 4.0 Web Patch Build 902 is intended for use with RealView Development Suite (RVDS) 4.0 products. It can be used to update any RVDS 4.0 Standard, Professional or Evaluation installation, whether previously patched or an original installation. It is NOT compatible with other releases of RVCT/RVDS or Keil MDK products.
This patch consists of updated RVCT/RVDS 4.0 compiler, linker, assembler, fromelf, and armar program executables, include files and C/C++ libraries.
Enhancements and CorrectionsDetails of the enhancements and corrections implemented by this patch are available on the ARM websiteOS Platforms
This patch has been tested on the following supported platforms:
  • Windows 7
  • Windows XP SP2, 32-bit & 64-bit
  • Windows XP SP3, 32-bit
  • Windows Vista Business Edition SP1, 32-bit & 64-bit
  • Windows Vista Enterprise Edition SP1, 32-bit & 64-bit
  • Windows Server 2003 32-bit & 64-bit
  • Red Hat Linux Enterprise 4 for x86, 32-bit & 64-bit
  • Red Hat Linux Enterprise 5 for x86, 32-bit & 64-bit
  • Solaris for SPARC 10
In addition, the patch has been tested on the following non-supported platforms:
  • Windows 2000 SP4
  • SUSE Linux 9.2
  • Ubuntu Linux 8.10
Installation Instructions
To install the patch carry out the following steps:
  • Ensure that you are currently using RVCT 4.0. To do this, type:
    armcc --vsn
    and ensure that this returns RVCT 4.0 build 400 or later.
  • Extract all the files from the ZIP file into a temporary directory.
  • Copy the include directory from the temporary directory to replace your existing include directory. The existing directory can be located by the RVCT40INCenvironment variable, e.g:
    > echo $RVCT40INC
    ~/ARM/RVCT/Data/4.0/400/include/
  • Copy the lib directory from the temporary directory to replace your existing lib directory. The existing directory can be located by the RVCT40LIB environment variable, e.g.:
    > echo $RVCT40LIB
    ~/ARM/RVCT/Data/4.0/400/lib/
  • Copy the linux-pentium directory from the temporary directory to replace your existing linux-pentium directory. The existing directory can be located by the RVCT40BINenvironment variable, e.g.:
    > echo $RVCT40BIN
    ~/ARM/RVCT/Programs/4.0/400/linux-pentium/
  • The updated tools should now have been installed. To confirm this, open a DOS command prompt window and enter:
    armcc --vsn
    armlink --vsn
    armasm --vsn
    fromelf --vsn
    armar --vsn
    The version returned should be RVCT 4.0 build 902.
  • After unzipping the executables, you may find that they cannot be executed because the UNIX permissions have been reset. The workaround is to set the execute permissions for the user with, e.g.:
    chmod u+x armcc
站长推荐上一条 /5 下一条
GMT+8, 2025-1-11 20:20 , Processed in 0.322722 second(s), Total 33, Slave 25 queries .
